Well he told me the water pump was done recently or 'looked newer' ..like the PO had told me. He checked it, said somthing about bearings..and said it didn't need to be done. There was two timing belts, a big one and a small one....I asked him to give me the old belts...and they don't look worn at all, certainly not near the point that they would be a danger. I mean I believe in preventative maintenance as well...and better to get this done and out of the way.
He also checked the antifreeze and said it was only slightly acidic...he flushed it and put new antifreeze in. Hoses were good. I mean I gave this guy license to change and fix lots of things. Whether or not he did too little remains to be seen. He came highly recommended, it's obvious he takes great pride in his work and his business.
I am happy and satisfied that the final bill was only $521 with tax included. He also replaced a leaking oil pressure switch. Here's how the bill read:
goodyear camshaft drive, timing belt $78.90
goodyear balance shaft drive, timing belt $34.35
Oil pressure switch $19.25
5W30 Full synthetic engine oil. 0.5L $4.23
Engine antifreeze-aluminum compatible 5 litres $18.75
Shop supplies $5.00
Labor:
Remove and install timing belt covers to replace both timing belts, check cam timing, adjust belt to proper tension, check for oil leaks. Chack accessory drive belts, computer scan. 3.8 hours @ $65. $247.00
Locate engine oil leak, replace leaking oil pressure switch, top up engine oil. ( I asked him to top up the oil...the tow truck driver told me it was low...)
0.5 hours $32.50
Drain, flush and refill cooling system with new coolant, check hoses (good) 0.8 hours$52.00
Water pump in good condition, not replaced.
195,769 Kms on OD.
So that is it folks...hopefully I'll have many more months of worry free enjoyable driving in my sexy baby...lol. Now for that rust spot on the door...damn there's always something else.
