This was common on the early ION's as well. The squeak is caused by the clutch push rod squeaking against the clutch master cylinder, the simplest fix is to get a can of white lithium grease, and push the straw through past the rubber boot on the clutch rod & giving the end of the pushrod/front on master a small shot of grease, work the pedal a few times and the noise will be gone.
