Fact is the PT Cruisers have a better than average reliability....despite the Neon connection...so maybe he did get a LEMON...FACTS please gentlemen,,now I'm leaving....DODGE.....
'em BULLITTS......
Fact : a statement or assertion of verified information about something that is the case or has happened
http://www.ptcruiserproblems.com/chrysler/pt_cruiser/pt_cruiser_owner_complaints.htmand these found at http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
Report Date : December 29, 2006 at 10:18 PM
SEARCH TYPE : VEHICLE
YEAR : 2004
Make : CHRYSLER
Model : PT CRUISER
Results : 27 | All records displayed
Make : CHRYSLER Model : PT CRUISER Year : 2004
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 0900105 Date of Bulletin: DEC 10, 2005
NHTSA Item Number: 10013774
Component: ENGINE AND ENGINE COOLING
Summary:
CYLINDER HEAD BOLT RE-TORQUE PROCEDURE. GPOP - ISSUE REVIEW SYSTEM. *TT
Check to Request Research. Submit below.
Service Bulletin Num : 1900805 Date of Bulletin: NOV 02, 2005
NHTSA Item Number: 10017651
Component: STEERING
Summary:
REVISED POWER STEERING SYSTEM BLEEDING PROCEDURES. *SC
Service Bulletin Num : 1803605 Date of Bulletin: OCT 07, 2005
NHTSA Item Number: 10017630
Component: STEERING:HYDRAULIC POWER ASSIST SYSTEM
Summary:
FLASH: ROUGH IDLE OR IDLE FLUCTUATION WITH POWER STEERING OPERATION. *SC
Service Bulletin Num : 0802801 Date of Bulletin: AUG 16, 2005
NHTSA Item Number: 629139
Component: EXTERIOR LIGHTING:HEADLIGHTS
Summary:
MOISTURE ACCUMULATION INSIDE A VENTED HEADLAMP ASSEMBLY CONDITION. *TT
Service Bulletin Num : 2304304 Date of Bulletin: MAR 09, 2005
NHTSA Item Number: 10013780
Component: OTHER
Summary:
TRANSIT FILM REMOVAL. 2006 CHRYSLER PT CRUISER, AND 2005-2006 RAM TRUCK *SC
Service Bulletin Num : 0801505 Date of Bulletin: MAR 02, 2005
NHTSA Item Number: 10013731
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
POWERTRAIN CONTROL MODULE INITIALIZATION. *SC
Service Bulletin Num : 0600105 Date of Bulletin: FEB 19, 2005
NHTSA Item Number: 10012813
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary:
TRANSMISSION GEAR RATTLE SOUND AT IDLE. *TT
Service Bulletin Num : 0801405 Date of Bulletin: FEB 17, 2005
NHTSA Item Number: 10012809
Component: ELECTRICAL SYSTEM
Summary:
MOPAR ACCESSORY REMOTE STARTER INOPERATIVE DUE TO HOOD SWITCH. *TT
Service Bulletin Num : 1901004 Date of Bulletin: NOV 29, 2004
NHTSA Item Number: 10011958
Component: STEERING
Summary:
POWER STEERING FLUID CONTAMINATION. *TT
Service Bulletin Num : 2100804 Date of Bulletin: OCT 16, 2004
NHTSA Item Number: 10008383
Summary:
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION -DIAGNOSTIC TROUBLE CODE (DTC) P1776 SOLENOID SWITCH VALVE LATCHED IN LR POSITION. *MJ THIS BULLETIN REPLACES 21-008-04 DATED JUNE 1, 2004. *TT
Service Bulletin Num : 0300604 Date of Bulletin: SEP 15, 2004
NHTSA Item Number: 10010478
Component: POWER TRAIN:AXLE ASSEMBLY:AXLE SHAFT
Summary:
FRONT HUB/HALF SHAFT CLICK/POP SOUND. *TT
Service Bulletin Num : 35 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10010493
Component: VISIBILITY:REARVIEW MIRRORS/DEVICES:EXTERIOR
Summary:
AN INCORRECT RIGHT SIDE VIEW MIRROR WAS INSTALLED ON APPROXIMATELY 20 VEHICLES. CUSTOMER SATISFACTION D35 - RIGHT SIDE MIRROR GLASS REPLACEMENT. *TT
Service Bulletin Num : 1900304 Date of Bulletin: AUG 27, 2004
NHTSA Item Number: 10009785
Component: STEERING
Summary:
STEERING COLUMN CLICK SOUND. *TT
Service Bulletin Num : 1802404 Date of Bulletin: JUN 01, 2004
NHTSA Item Number: 10008426
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
IDLE FLUCTUATION AND OR MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION DIAGNOSTIC TROUBLE CODES P0300, P0301, P0302, P0303 OR P0304. *TT
Service Bulletin Num : 1800604A Date of Bulletin: APR 06, 2004
NHTSA Item Number: 10005981
Summary:
GENERIC POWERTRAIN CONTROL MODULE (PCM) PROCEDURE. *TT *MJ THIS BULLETIN SUPERSEDES BULLETIN 18-006-04A DATED 04/06/2004. *TT
Service Bulletin Num : 1900402 Date of Bulletin: APR 06, 2004
NHTSA Item Number: 10007587
Component: STEERING:COLUMN
Summary:
STEERING COLUMN CLICK SOUND. *MJ
Service Bulletin Num : 1900104 Date of Bulletin: MAR 16, 2004
NHTSA Item Number: 10006448
Component: STEERING
Summary:
WHISTLING SOUND WHEN THE STEERING WHEEL IS TURNED. *TT
Service Bulletin Num : 0700104 Date of Bulletin: MAR 16, 2004
NHTSA Item Number: 10006459
Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS
Summary:
ACCESSORY DRIVE BELT SQUEAKING/CHIRPING SOUND. *TT
Service Bulletin Num : 0900704 Date of Bulletin: MAR 02, 2004
NHTSA Item Number: 10006455
Summary:
IRREGULAR ENGINE SNAPPING SOUND. *TT
Service Bulletin Num : 0803403 Date of Bulletin: MAR 02, 2004
NHTSA Item Number: 10007592
Summary:
NEW SPARK PLUG FOR 2.4L ENGINE. *MJ
Service Bulletin Num : 2100104 Date of Bulletin: FEB 10, 2004
NHTSA Item Number: 10005978
Summary:
TRANSMISSION SOLENOID REPLACEMENT. *TT
Service Bulletin Num : 03 Date of Bulletin: FEB 01, 2004
NHTSA Item Number: 10006003
Component: EQUIPMENT:OTHER:LABELS
Summary:
AN INCORRECT VEHICLE EMISSION CONTROL INFORMATION (VECI) LABEL WAS INADVERTENTLY INSTALLED. VECI LABEL REPLACEMENT. *TT
Service Bulletin Num : 30 Date of Bulletin: NOV 01, 2003
NHTSA Item Number: 10005354
Summary:
POWERTRAIN CONTROL MODULE (PCM) ELECTRICAL CONNECTOR SEAL CUSTOMER SATISFACTION NOTIFICATION NO. C30. *TT
Service Bulletin Num : 03014 Date of Bulletin: AUG 29, 2003
NHTSA Item Number: 10003520
Summary:
SERVICE ACTION 03014 - POWERTRAIN CONTROL MODULE (PCM) ELECTRICAL CONNECTOR SEAL INSPECTION/REPAIR PROCEDURE. *TT
Service Bulletin Num : 1800703C Date of Bulletin: AUG 15, 2003
NHTSA Item Number: 10003541
Summary:
GENERIC POWERTRAIN CONTROL MODULE (PCM) PROCEDURE. 2004 MODELS INCLUDED. *TT
Service Bulletin Num : 1800703B Date of Bulletin: JUL 25, 2003
NHTSA Item Number: 10003417
Summary:
Service Bulletin Num : 1800703A Date of Bulletin: JUL 04, 2003
NHTSA Item Number: 10003416
Summary:
