Pages: [1]   Go Down
Author Topic: 87 Mustang - battery keeps dying  (Read 2832 times)
06JettaTDI
member
« on: December 12, 2006, 12:07:57 pm »
I have an 87 Mustang with a 5L 4-bbl.  The battery and alternator are new.  If the car is left more than a week, the battery discharges and won't start.  Any suggestions Huh
2006 Jetta TDI - Spice Red, black leather, DSG, spoiler, all options
Arthur Dent
Drunk on Fuel
View Profile WWW
Champion of
« Reply #1 on: December 12, 2006, 12:26:27 pm »
I'd guess you have a wiring that is grounding its self.
initial_D
« Reply #2 on: December 12, 2006, 12:30:42 pm »
Do you have an aftermarket stereo, alarm, remote starter system installed?
articsteve
« Reply #3 on: December 12, 2006, 12:38:09 pm »
My first look would be to the ignition switch and that your juice is running out of the starter when off and the key is out.
One good thing about Ford of that era is they kept the starter solenoid off the starter and in the engine bay.  You could try disconnecting the hot wire to the solenoid when not in use or put a digital meter on it.
Go to a Mustang forum.  Smiley
« Last Edit: December 12, 2006, 12:47:33 pm by articsteve » Logged
06JettaTDI
member
« Reply #4 on: December 12, 2006, 02:11:18 pm »
yes, I have all that and detach the face-plate when the car is parked.  when I had the alternator replaced a few weeks ago, they checked the draw from that source and it was miniscule. Undecided
articsteve
« Reply #5 on: December 12, 2006, 05:54:06 pm »
Check the super obvious.  Glove box and trunk lid.
06JettaTDI
member
« Reply #6 on: December 13, 2006, 11:30:16 am »
Done and done-er.  Taking it back to the shop where I'm sure they'll replace yet another component in the electrical system and cross their fingers.  I have to admit, after the new alternator was installed, the old beast was easier to start - except after it had been sitting too long Sad
If the car hadn't belonged to my late mother...
Thanks for all the feedback!
initial_D
« Reply #7 on: December 13, 2006, 05:22:03 pm »
How did those 'shop guys' measure the total current draw?
You can stick an AMP meter on the positive terminal of the battery to measure the 'leakage' when the car is OFF, and turn the meter to DC Volt and measure each device that has a power connection ... the most difficult thing is to get to them ... when buried inside the dash ...
articsteve
« Reply #8 on: December 13, 2006, 07:16:55 pm »
How did those 'shop guys" conclude the starter and alternator needed replacement?  Roll Eyes
mar1990
member
« Reply #9 on: December 13, 2006, 09:03:19 pm »
To narrow down which circuit pull a fuse and stick the leads of the AMMETER on the two fuse connections to see what each branch is drawing. Do this one by one on each fuse, both under the dash and in the engine compartment.
06JettaTDI
member
« Reply #10 on: December 18, 2006, 02:48:03 pm »
The fellows at Fountain Tire informed me that the old (Motomaster) battery is hooped i.e. will not hold a charge.  So, I decided to have them put in a different one, and I took the "old" one back to Canadian Tire.  The idea was to get a replacement battery to keep as a spare.  CT charge the old battery and told me there's nothing wrong with it. Shocked
It will be interesting to see what happens now.  Depending on who I believe, either my electrical system is not causing the battery to die or I bought a new battery I didn't need. ROFL
barrie1
« Reply #11 on: December 18, 2006, 10:29:56 pm »
How many CCA's is this particular Battery you are having problems with as the Canadian Tire Batteries are not all really that good a product  for very long at all.  Smiley
06JettaTDI
member
« Reply #12 on: December 19, 2006, 01:42:52 pm »
Not sure about the Amps.  CT only had one battery that would fit my car.  With the 4-bbl instead of FI, it's a bit of chore to crank it over - although, the new alternator helps.  Time will tell. Undecided
barrie1
« Reply #13 on: December 19, 2006, 09:49:37 pm »
As a suggestion I would check the contact points on the inner fender well where the Solinoid and the brain box bolts onto. The legs on the bottom of these 2 devices have to have a nice clean surface on them as they actually ground with the part. Make sure theres No Rust under each foot part of them as it will create a short and can kill the Battery over a short period of time.  Smiley
Pages: [1]   Go Up
Page created in 0.071 seconds with 35 queries.
