Author Topic: Which cars do they fit  (Read 1157 times)
Offline punisher4u
« on: November 29, 2006, 01:55:38 pm »
I have a set of 4 winter steel rims 15" that I used on my Mazda Protege 5 2002 and I would like to know which other vehicles they can be used for. Are there any web sites that can provide this information? They are 5 bolt pattern.
Thanks
Offline BMG
Re: Which cars do they fit
« Reply #1 on: November 29, 2006, 06:45:17 pm »
They should be 5 X 4.5 (or metric 5 X 114.3).  If they are OE steels the center bore is 67.1.  If they are aftermarket steels I imagine the center bore would be larger than that.  The offset will be high probably +45mm.  The rims will fit any car with a high offset using the same bolt pattern.  A lot of imports use that bolt pattern if they have 5 bolts.
This website lists the bolt patterns.
http://www.discountedwheelwarehouse.com/Vehicle_Bolt_Pattern_Reference.cfm
Offline punisher4u
« Reply #2 on: November 30, 2006, 10:06:02 am »
Thanks BMG!
Excellent site.
Offline morty
  • A Life Less Ordinary!
    • http://www.tiretrends.com
« Reply #3 on: December 02, 2006, 10:40:21 pm »
These wheels will fit many mazda vehciles including Protege ES, MPV, Mazda3 Sedan.
