Why do you guys keep putting Santa Fe and XL7 in the same class with RAV4? It doesn't take a rocket scientist to see the difference. Use Highlander for comparison with Santa Fe and XL7, or compare RAV4 with Grand Vitara and Escape. It's very simple ... and more accurate. Or, make a note that you are cross comparing between classes and the confusion will be avoided. But than, what's the point comparing apples to oranges? We all know that they are different but in the same time they have something in common: they are both fruits.
In regards to Nitro, I don't think it can be compared with RAV4 either. Not sure what compares with though...
Just my 2 cents...
Euh I don't understand your point and I don't think you went at the dealer see the new RAV4.. The new RAV4 is way bigger than the one it replace and it now about the same size of a SanteFee, Equinox, Nitro, etc.
Here's the RAV4, XL-7 and SanteFee have seating for 7 passengers not the Nitro or the Grand Vitara.
Can't wait to see the result of the comparaison.
Your assumption is wrong: I test drove the RAV4 Sport and I studied both cars as I'm in the market for a compact SUV. I also spend endless hours reading car reviews and car forums as this is my hobby.
However, my point is that, in Toyota's line up, the RAV4 is the compact SUV, in Hyundai's line up Tucson is the compact SUV and in Suzuki's line up the Grand Vitara is the compact SUV. The next size up is Highlander, Santa Fe and XL7. If you look at each vehicle overall, interior feature set, driving characteristics, size etc., you will see my point.
Just because RAV4 is such a good package - the best in its class IMHO, it doesn't automatically make it a mid-size SUV.
Anyway just check at bmorton post and also look at the dimensions in this article. RAV4 and Sante Fee are in the same class.
The Tucson is not competitor of the RAV4; Grand Vitara, CR-V and Patriot are in terms of size. The Highlander is nearly over 40K$ and next generation will be bigger than the current.
I think we should start to use same terminology as for the car for SUV classification:
Sub-compct SUV
compact SUV
Midsize SUV
Large SUV.
X-Large SUV
I put the numbers together to support my point:
RAV4 V6 LTD Santa Fe AWD 5AT Highlander AWD
(7 seats) (7 seats) (7 seats)
Length (in) 181.1 184.1 184.6
Wheel base (in) 104.7 106.3 106.9
Height (in) 69.1 67.9 68.3
Width (in) 71.5 74.4 71.9
Ground clearence (in) 7.5 7.3
Weight (lbs.) 3675 4121 3935
Source: www. toyota.ca, hyundaiusa.com (they provide the dimensions in inches so no need for conversion).
Hyundai does not list the ground clearance, but this is not very important. I think it is under 7.5 inches anyway.
Now you tell me which Toyota model is the Santa Fe closer to based on the dimensions.
I rest my case...
Yeah, a sub-compact SUV class would help.
