Speedbleeders are really nice, basically bleed nipples with one-way valves that make the job one person and much simpler.
https://www.speedbleeder.com/They also sell a catch container for the fluid, the really useful part is the surgical tubing which grabs the bleeder nipple much better than regular tubing.
When pumping the brake pedal, put a 2X4 or some small block under it so the pedal doesn't go quite to the floor, some master cylinders will screw up the rubber seals if you go all the way down.
Some master cylinders are very tough to bleed properly, I found that starting the engine and letting it run during the process helped get recaltriant bubbles out of the system.
Worst comes to worst, Midas and such will pressure bleed a system quite cheaply.
