hi guys i am new to this site in reference to
Umm... I found that letting my 2003 VW Golf sit for more than 2 or 3 weeks (like over a long vacation) caused the battery to drain; I don't know if the older models do that... The dealership said it's not a bug, it's a feature. So I have to but a "trickle charger", which uses a solar panel)the newer model are prone to discharging after about 2 weeks of sitting due to drainage from the radio and built in alarm system ,like elf da said try using the solar panel that usually comes with these cars that the dealer never give with the new cars.
when the battery drains the famous ck engine ligth comes on and also the air bag ligth ,when the tech purges the memory with the dealers computer it`s usually cause by a fault listed with low supply voltage and they will erase the faults and set you on your way.
(Message edited by skywalker407 on November 15, 2004)
