Hey everyone.
I bought a used 2004 Acura TSX w/ 72,000km's, from an Acura dealer. Long story short, the car was burning 1 litre of oil every 1000 km's, no matter what the driving style, terrain, or oil used.
Acura warrantied the engine, providing a REBUILD: Piston rings, valve seals, all gaskets, head bolts, honed cylinder walls. The ultimate cause of the original oil burning was improper break-in (highway) leading to carbonization of the oil control rings (each one was carbon'd and wouldn't rotate at all. Each piston was washed. All were cleaned up and new rings put in as I mentioned above).
My question is this: After 1,000km on the rebuild, I was down 1 litre of oil, AGAIN. After the first 500 km it was still honey colored and only down a slight bit. But at 1,000 km it was dark brown and down 1 litre. I broke it in using a moderate version of the mototuneusa method (driving it fairly aggressively but no constant redline). IS IT NORMAL TO USE 1 L OF OIL IN 1000 KM ON A FRESH REBUILD?? WILL IT GET BETTER??
The above question can be answered as if the engine was NEW as well, because internally, they basically are.
So, anyone here know or have experience with brand new or rebuilt engines burning oil initially??
Thanks everyone,
Eric
