"Tpl: I think with only 2-3 months left on the brakes ( I presume that the pads are low and the rotors after only a year or so are ok.) I would change them now" - Apparently the brakes warranty has expired..upto 20,000km.. I had issues with my brakes ( created another thread for that issue on this forum last month). Long storry short,last month, i flushed the brake fluid, and gave them to do servicing . But i hate how they serviced the rear drum.. He just sanded the shoe and the drum..voila all done :S . As for the front shoe, Mitsu mechanic said 50% of the pads is used and its good to go for another few months. As for the front rotor, they installed a new one when i bought the car.
"Safaristi: An original Mitsu air filter and decent Synthetic 10/30 with top of the line filter is all ya need. Mobil-1 and Amsoil are available at Crappy Tire and are top notch" - I am still inclined to get the K&N air filter as i read in another forum, that it helps alot in gaining HP ( which i badly need..horrible pickup ). As for the oil, most likely i *might* stick with Mobil-1 since articsteve replied stating he hasn't used it yet.
"Safristi: Make sure ya polish the exhaust weekly !!!!!first new car OCD requirement" - LoL sure will
"Barrie1: As a suggestion I would approach your dealer to obtain the original Factory service manuel for this car" - I do have another booklet by Mitsubishi that came with the car, called " Warranty & maintainence manual" . Is that what your refering to? if so, i will scan the page for 24,000Km maintainence routine.
"barrie1: I agree with TPL on your brakes as you don't want to run them too low as they could then score the rotors and cost more then required to replace" - Ok, i will get them changed next month for sure. I am still trying to see if i can get the front brakes upgraded to a bigger rotor and twin callipers. Any idea how much that will cost me lol? Or get the rear drums replaced by Disc brakes. ( Lancer has shitty braking power )
"Arcticsteve: My 2 cents is to switch out the brake pads now. Why bother waiting? You don't want to heat stress the rotors. Make sure rear drums are adjusted and lube hardware. " - Thats next on my todo list. As for servicing it, Mitsu dealer did a shitty job on it. They didnt even lube it!!! just sanded the shoe and the drums o_0. Also, while i had my brakes problem, i did goto Midas for brake inspection ( last month), they said the front shoes were good for few months and the back drums needed machining & probably servicing. Midas guy said to take it back to dealer since 30 days didnt pass and get them to do it. After pressuring the Mitsu service guy to do it, he said he will do it but the mechanic did a shitty job.
"Arcticsteve: Get air filter at dealer until warranty expires. Don't get a K&N" - Just outta curiousity, is there anything wrong with the K&N filter? I mean the Mitsubishi service department sells them ( $99 for my car) and Cdn Tire recommended that for me ( altho i don't buy that;sales tactic)
"Arcticsteve: Not many aftermarket parts for the car. Get the pads from the dealer. I bought some Talon parts off a Mitsu dealer in Markham and they were good on price and getting the order shipped" - Thats where i go for my parts ordering now..have bad experience with Cooksville Mitsu.
"Arcticsteve: If the tranny pan has a drain plug I would drain it NOW and every third oil change and add (refresh) that amount which will be about 3 litres" - Can this be done at home, or has to be done by a mechanic?. Coz i heard my friend saying i would need some gauge to fill exact liquid level and is very critical.
"Arcticsteve: Change fuel filter NOW" - Didn't know about that :S nor my manual said anything about that. I am guessing i get that from the dealer too?
"Barrie1: Mikron15 save the money on the spark plugs as you don't need them yet at all" - The waarnaty manual says to get it changed at 24,000km, so did the Mitsu mechanic. Spark plugs aint that expensive, so i don't mind changing that
"Boxgrover: The 0W-30 really is a full PAO 100% synthetic. And from what I have read Mobil and Esso are very independent with respect to their engine oil production...lucky for us Canadians" - Assuming his fact is right, Mobil1 price is 2x the Esso brand
Once again, thanks guys all for your quick replies and usefull suggestions.}
