Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
May 26, 2012, 04:02:23 am
Home
Help
Search
Calendar
Chat
Login
Register
Autos.ca
Buyer's Guide
Test Drives
Autos News
Used Cars
Video Reviews
Autos
The Garage
Tire & wheel Talk
Topic:
Car pulls easier to sides with new lighter rims and tires
« previous
next »
Pages: [
1
Go Down
Author
Topic: Car pulls easier to sides with new lighter rims and tires (Read 1075 times)
chaser
Carma: +0/-0
on:
May 18, 2005, 05:45:11 pm »
I've got a set of new rims & tires (Falken ZE512, 215/45/17) recently. The new rim/tire combo is about 7.5lb lighter per each corner than the stock. The stock tires are Goodyear RS-A, 205/50/17.
I notice now that the car (steering wheel) is more easier to pull to left/right when driving over un-even surface. Is it because of the lighter weight? 10mm wider of rubber? Or the Falken ZE512?
Thanks
capriracer
Carma: +0/-0
Reply #1 on:
May 18, 2005, 07:44:37 pm »
You didn't say what rim widths you had, but I suspect the wider tires are "arching" just a bit more.
smokeshowjoe
Carma: +0/-0
Reply #2 on:
May 18, 2005, 10:25:58 pm »
Hmmm..what pressure are you running them at? Is arching the same as crowning wrt to the centre of the tire tread becoming seemingly overinflated?
That could cause the dancing between grooves/ ruts at hwy speeds..translating into lighter steering -no?
smokeshowjoe
Carma: +0/-0
Reply #3 on:
May 18, 2005, 10:27:55 pm »
Also, the 7.5 pound reduction in mass per wheel thus reducing unsprung weight would be noticeable in steering...
chaser
Carma: +0/-0
Reply #4 on:
May 19, 2005, 11:49:55 am »
Stock rim is 6.5" wide and I was running at 32psi (factory recommanded)
New rim is 7" wide and I'm running at 35psi.
Thanks guys.
davidm
Drunk on Fuel
Carma: +0/-0
Reply #5 on:
May 19, 2005, 02:27:04 pm »
Higher pressure, wider tire, lighter wheel, grippier tire - all usually lead to tramlining. I would start by lightening up on the pressure. 7.5 lbs/corner is a fabulous drop in weight, should be much nicer handler now.
Pages: [
1
Go Up
« previous
next »
Autos
The Garage
Tire & wheel Talk
Topic:
