If budget is an issue, check with a local auto wrecker/recycler for the same vehicle make, model and year.
Otherwise, you can upgrade your speakers to better sounding ones. If you upgrade, make sure that you budget some sound deadning material like Brown Bread or the expensive Dynamat.
Any changes should allow your speakers to be matched. If not, the sound will be different from one side to the other.
Dave
