Pages: [1]   Go Down
Author Topic: 35 Max PSI. What does everyone usually run??  (Read 3389 times)
xtreme02
« on: November 27, 2004, 06:34:03 pm »
Have snows with max 35 PSI.  Was thinking of running them at about 32 PSI.
Any thoughts.  I'm trying to get max life out of the tires.
Thanks
ovr50
« Reply #1 on: November 27, 2004, 07:32:57 pm »
I run 30 to 32 just about all the time.
and
ericthejet
« Reply #2 on: November 27, 2004, 07:53:13 pm »
I run what the sticker on the door jam calls for. 32psi.  Is that not the rule or can you play around a bit?
I miss my motorcycle!
random006
Vehicle: 2003 Kia Sorento EX
« Reply #3 on: November 27, 2004, 08:38:53 pm »
The recommended pressure is 30 psi front and back for my vehicle.  However, the Kia dealership and my regular tire garage both have my tires at 30 - 33 psi or so.
I find that pressure range to be acceptable so I maintain it.  Again, I make sure all 4 tires have the same pressure whether they are winter or all season.
sirAQUAMAN64
Board Moderator
Vehicle: 2010 Volkswagen Golf Wagen TDI Comfortline 6MT. 2009 Dodge Ram 1500 Crew Cab Sport 4X4
View Profile WWW
« Reply #4 on: November 28, 2004, 03:41:37 pm »
My wheel (which is different size and brand than the one that came on the car) says max PSI of 44, so I try and keep it at 42.
ovr50
« Reply #5 on: November 28, 2004, 03:59:39 pm »
Sir - I think you should be going by the vehicle rating for air pressure on the door sticker; not by what the tire says is max. pressure. I've never heard of anyone running 42 pounds on a daily basis. Must ride like a chuckwagon...
and
safristi
« Reply #6 on: November 28, 2004, 04:04:25 pm »
Put them on a diet and lose 10lbs in each of them
Wagons Ho..!! unless your running it underwater
AquaMan.Ovr50 is just his "name-de post" inflated
ego or IQ..which is it...
ovr50
« Reply #7 on: November 28, 2004, 05:58:50 pm »
IQ and just barely..........
and
Driver
Vehicle: 2005 BMW X3 2.5i
« Reply #8 on: November 28, 2004, 08:30:17 pm »
Sir, I ran 40psi on my Subie's new W300 IceBear from TireTrends when the door jam says 32F/29R.  I drove it 650kms and found that fuel economy was better than EPA mileage ratings and steering was light BUT ride was harsh.  That night I couldn't sleep well as I still feel the vibrations on my skin from the 7 hour trip. It's like sitting on a massage chair for a long time and after getting home, I still feel them all over.  Not pleasant at all.
Now I run 35 psi (as recommended by Morty and Saffy).  Ride is a whole lot better.
I also read somewhere a simplified guideline for us regular drivers... "it's better to have your tires 3 psi overinflated than under"  when the temperature drops from 0 to -15C, our tires loose 3 psi.  The extra 3 psi added a while back gives you reasonable buffer to keep you safe on the road
barrie1
« Reply #9 on: November 28, 2004, 09:14:15 pm »
Because my vehicles are all larger full size cars and truck with 15" wheels I run 36 to 40 Lbs in them all. I find a better ride and better gas milage on all 3 of them from doing this. I also find I get a little longer life out of the tires as well. These are heavy vehicles and hold the road very well at these pressures.
bmorton
« Reply #10 on: November 29, 2004, 10:22:36 am »
Same car as Crolly--door says 32/29, I run 3 psi over that or 35/32. I find running 3-5 psi higher than specs increases fuel economy and improves handling without a real penalty in ride quality. I just bought a used RAV4 as a second car and its tires are rated at 35 psi max but Toyota's recommendation is 28/26. I'll probably start at 31/29 and then go up or down depending on what I think.
ghost
« Reply #11 on: November 29, 2004, 11:27:51 am »
35 all around for me during street driving. The winter tires' sidewall is too squishy. low psi results in sidewall folding. Maybe i should use the brakes when I turn....
Pages: [1]   Go Up
Page created in 0.059 seconds with 33 queries.
