Pages: [1]   Go Down
Author Topic: 0xygen sensor  (Read 3046 times)
johnturner
« on: October 01, 2004, 11:47:17 pm »
Are there any side effects of driving with a oxygen sensor thats not working properly? Apart from worse gas mileage?
Thanks!
pikacha10
« Reply #1 on: October 02, 2004, 03:00:53 am »
you will most likely fail any emissions test, and polute the enviorment alot more
The most wanted cars of my uber uber list
4th generation supra with twin turbo which is the most affordable/practical on the list
If i had all the money in the world, i would buy an army of Supras and crash them into the tree stumps
barrie1
« Reply #2 on: October 02, 2004, 03:17:50 am »
You may start loosing power on the faster streets and it dosen't do much good for your engine at all. You do need it running correctly.
johnturner
« Reply #3 on: October 02, 2004, 11:39:53 am »
Hey Barrie.
Thanks. Its actually a Volvo 850. The light has been reset. So if it comes on again time to change the 02 sensor. Are you familiar with these cars? I hear they are 2 sensors. Not sure which one needs changing though.
articsteve
« Reply #4 on: October 02, 2004, 12:53:25 pm »
http://www.volvospeed.com/volvo_performance.php
Enter, go to sensors.
Nowhere on the net does a more comprehensive site exist for one series of car.
850s and to a lesser extent S70s were a very popular car.  S60 comes along and bombs in North America.  Volvo must be still scratching their heads over that one.
rtech
« Reply #5 on: November 04, 2004, 10:57:12 pm »
Just because you have a code for an O2 sensor dose not mean that it is the O2 sensor that needs to be changed.
If you have an intake Vacc leak it will set an O2 code
If you have a weak fuel pump or a plugged fuel filter it can set an O2 cade
If your converter efficiency is poor it can set an O2 code
Depending on the year of the car ( OBDI or OBDII ) an O2 code can be set by a bad spark plug/ plug wire or a fouled injector.
The replacement of O2 sensors is a good maintenance item but to replace them when they are not the cause of your concern but only the effected part is simply a waist of money and results in your vehicle remaining inefficient and possibley doing itself other harm.
barrie1
« Reply #6 on: November 04, 2004, 11:06:48 pm »
Good Post Rtech, Welcome to the Forum as well.
johngenx
« Reply #7 on: November 05, 2004, 12:30:55 am »
A faulty fuel trim device (O2 sensor, air flow sensor, air mass sensor) can cause the fuel system to compensate rich and the added fuel load can destroy the catalytic converter.  Priced one out?  It's typically MUCH cheaper to replace the O2 sensor.
No place I'd rather be...
suds
Vehicle: 2003 legacy wagon se
« Reply #8 on: November 05, 2004, 08:24:12 pm »
okay,let me get this strait. u have a volvo 850
that had its cel reset,which said that the o2 sensor was bad.get the o2 sensor relaced.
it may cost u, but its better than leaving it
for latter.
maritime_storm
« Reply #9 on: November 06, 2004, 03:56:28 am »
Rich running also causes cylinder wall wear to increase because more fuel in the mixture washes the oil off the cylinder walls even more. Change the sensors and save money in the long run.
johnturner
« Reply #10 on: November 06, 2004, 10:44:14 pm »
Thanks a lot. Lots of helpful advice. Currently looking for a mechanic to replace it. Do you think I should go to a volvo specialist? Or can any mechanic fix it?
maritime_storm
« Reply #11 on: November 07, 2004, 02:57:05 am »
Anyone, yourself included, can change them, they screw into usually both the exhaust manifold and after the cat. converter & plug into the wiring harness. Not a real technical part to change, though sometimes difficult to access and/or unthread.
Pages: [1]   Go Up
Page created in 0.064 seconds with 33 queries.
