When i said i've had few problems in the past, i may have been deluding myself.
After thinking about it, i decided to make a list of repairs i've made during the time i've owned this vehicle. What i am wondering is, if this should be considered excessive or not and what you guys would advise in general.
As mentioned before, i just replaced:
front rotors
front wheel bearings
rear struts
new tires all around
During the previous 4.5 years (I was mistaken, i bought the car in 99) i've replaced:
Driver-side front caliper
A/C condensor (which needs to replaced again)
A/C compressor
rear rotors
heater motor (twice)
Passenger side, fog lamp (the whole assembly)
fan switch (twice)
front headlight assembly (both sides)
a pair of tires
control arms, tie rods, and bushings
I not including regular maint stuff like break pads, spark plugs, etc.
My paint job is also hurting. Numerous paint chips, and scratches, the clear coat is flaking off, and the paint itself is coming off in chips around the rear wheel wells on both sides. Of course rust is forming, and i was quoted $2500 to repaint the beast.
To top everything off, i have a slight oil, and transmission fluid leak.
After all that, i am starting to lean towards keeping the car since it is still running strong and is paid for.
So there it is. Any input would be appreciated.
